tiny fret file handle? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=46901 |
Author: | wbergman [ Thu Dec 24, 2015 2:46 pm ] |
Post subject: | tiny fret file handle? |
I have some tiny fret files that are about an inch long block of steel with a v-groove lined with diamond dust. They are used to crown frets in a pyramid shape. Apparently, other people just pinch these little blocks and have at the frets. My fingers cannot deal with that. Before I try to invent a handle, has anybody else either invented a handle or seen one for sale? |
Author: | Tom West [ Thu Dec 24, 2015 2:57 pm ] |
Post subject: | Re: tiny fret file handle? |
http://www.stewmac.com/Luthier_Tools/Ty ... _File.html How about this.............? Tom hla edn |
Author: | Chris Pile [ Thu Dec 24, 2015 3:17 pm ] |
Well.... that won't work. |
Author: | wbergman [ Thu Dec 24, 2015 4:40 pm ] |
http://www.ebay.com/itm/Fret-Dressing-F ... Swd0BV3VrS Mine are the same or similar to this. The StewMac handle won't fit them. |
Author: | Chris Pile [ Thu Dec 24, 2015 5:14 pm ] |
Yeah, that's what I thought they were. Suggest you embed them in wads of mixed bondo, and shape them for comfort after it hardens. |
Author: | wbergman [ Thu Dec 24, 2015 5:35 pm ] |
I was considering Bondo, but I am worried that eventually it will pop loose right when I am bearing down and I will ruin something. Anyway, I'll probably try it. |
Author: | Colin North [ Thu Dec 24, 2015 7:00 pm ] |
Just CA or Araldite it to a piece of wood of your choice. |
Author: | Barry Daniels [ Thu Dec 24, 2015 7:26 pm ] |
Those are strange files. I don't understand how they could work. I like my frets rounded, not V-shaped. Also, the file on eBay looks too deep and it would be hitting the fretboard before the fret. |
Author: | DennisK [ Fri Dec 25, 2015 7:07 pm ] |
Barry Daniels wrote: Those are strange files. I don't understand how they could work. I like my frets rounded, not V-shaped. Also, the file on eBay looks too deep and it would be hitting the fretboard before the fret. It does ride on the fretboard. The deepest part of the V is never used. You work each side of the fret individually, applying sideways pressure against the fret while you slide the file back and forth. The file has two angles, so you do get a faceted fret (steep upward from the fretboard, then a shallower angle, then the flat leveled surface at the peak), but a few rubs with sandpaper smooth out the facets. |
Author: | Barry Daniels [ Fri Dec 25, 2015 9:30 pm ] |
I understand. Interesting approach. Do you protect the fretboard with masking tape or something so you don't get side to side scratches? |
Author: | DennisK [ Sat Dec 26, 2015 12:23 am ] |
Barry Daniels wrote: I understand. Interesting approach. Do you protect the fretboard with masking tape or something so you don't get side to side scratches? I would... keep the metal dust out of the wood too. |
Author: | wbergman [ Sat Dec 26, 2015 1:20 pm ] |
I made the handle combining advice from two above. I shaped a scrap of wood into a handle to clear my knuckles from the guitar top, made a recess and used Bondo to glue the file into the handle. Before gluing, I notched the file block to help secure the Bondo. I have not tried it yet. I also did not know that the two different slopes in the file were to shape a facet. I just thought the steeper slope was the side towards the bridge. I have not tried it yet. |
Author: | wbergman [ Sat Dec 26, 2015 5:33 pm ] |
I just looked closely to find that only one surface is abrasive on each of the files I have. |
Author: | Bryan Bear [ Sat Dec 26, 2015 9:24 pm ] |
Interesting. Dennis, have you used these? Do you like them? |
Author: | unkabob [ Sat Dec 26, 2015 9:43 pm ] |
Could you drill and bolt a handle on using four holes and a crushed piece of steel or copper tubing. Bob ![]() |
Author: | DennisK [ Sat Dec 26, 2015 10:31 pm ] |
Bryan Bear wrote: Interesting. Dennis, have you used these? Do you like them? No, but I have been wanting to get one and try it. I currently use a StewMac offset diamond file, which gets the job done, but isn't really worth the high price IMO since it also requires working the two sides of the fret individually due to its large radius. |
